Energy-aware Adaptive Attitude Estimation Under External Acceleration for Pedestrian Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ASME Transactions on Mechatronics Année : 2016
Hassen Fourati
Alain Kibangou
In this paper, we consider the problem of rigid bodyattitudeestimationunderexternalaccelerationusingasmallinertial/magneticsensors module containing a triad of gyroscope, accelerometer,andmagnetometer.Thepaperisfocusedontwomainchallenges. The first challenge concerns the attitude estimationduring dynamic case, in which external acceleration occurs. Thislatter leads to lose performance in attitude estimation methods. Aquaternion-based adaptive Kalman filter (q-AKF) compensatingexternal acceleration from the residual in the accelerometer isdesigned. At each step, the covariance matrix of the externalacceleration is estimated to tune the filter gain adaptively. Thesecond challenge is related to the energy consumption issue ofgyroscope. In order to ensure a longer battery life for the InertialMeasurement Units (IMUs), we study the way to reduce the gyromeasurements acquisition by switching on/off the sensor whilemaintaining an acceptable attitude estimation. A smart detectionapproach isproposed to decide whether the body is indynamic orstatic case. The efficiency of the q-AKF is demonstrated throughnumerical simulations and experimental tests.
MFK_final_version.pdf (2.08 Mo) Télécharger le fichier
hal-01241403 , version 1 (24-11-2016)
Aida Makni, Hassen Fourati, Alain Kibangou. Energy-aware Adaptive Attitude Estimation Under External Acceleration for Pedestrian Navigation. IEEE/ASME Transactions on Mechatronics, 2016, 21 (3), pp.1366-1375. ⟨10.1109/TMECH.2015.2509783⟩. ⟨hal-01241403⟩
425 Consultations
365 Téléchargements
