Particle system algorithm and chaos propagation related to non-conservative McKean type stochastic differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We discuss numerical aspects related to a new class of nonlinear Stochastic Differential Equations in the sense of McKean, which are supposed to represent non conservative nonlinear Partial Differential equations (PDEs). We propose an original interacting particle system for which we discuss the propagation of chaos. We consider a time-discretized approximation of this particle system to which we associate a random function which is proved to converge to a solution of a regularized version of a nonlinear PDE.
NonConservativePDEPart2 (1).pdf (392.49 Ko) Télécharger le fichier
NonConservativePDEPart2.pdf (392.49 Ko) Télécharger le fichier
hal-01241704 , version 1 (10-12-2015)
hal-01241704 , version 2 (02-08-2016)
  • HAL Id : hal-01241704 , version 1
Anthony Le Cavil, Nadia Oudjane, Francesco Russo. Particle system algorithm and chaos propagation related to non-conservative McKean type stochastic differential equations. 2015. ⟨hal-01241704v1⟩
254 Consultations
259 Téléchargements
