Chaskey: a MAC Algorithm for Microcontrollers – Status Update and Proposal of Chaskey-12 – - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
The Chaskey MAC algorithm was presented by Mouha et al. at SAC 2014. It is designed for real-world applications where 128-bit keys are required, but standard cryptographic algorithms cannot be implemented because of stringent requirements on speed, energy consumption, or code size. Shortly after its publication, Chaskey was considered for standardization by ISO/IEC JTC 1/SC 27/WG 2. At the October 2015 meeting, the ISO/IEC committee decided to terminate the study period on Chaskey, and to circulate a first working draft. Since Chaskey was introduced, many follow-up results were published, including improved cryptanalysis results, new security proofs and more efficient implementations. This paper gives a comprehensive overview of those results, and introduces a twelve-round variant of Chaskey: Chaskey-12. Although the original eight-round Chaskey remains unbroken, Chaskey-12 has a much more conservative design, while reducing the performance by only 15% to 30%, depending on the platform.
1182.pdf (104.89 Ko) Télécharger le fichier
hal-01242648 , version 1 (13-12-2015)
  • HAL Id : hal-01242648 , version 1
Nicky Mouha. Chaskey: a MAC Algorithm for Microcontrollers – Status Update and Proposal of Chaskey-12 –. [Research Report] Inria Paris Rocquencourt. 2015. ⟨hal-01242648⟩
237 Consultations
469 Téléchargements
