TiPEX: A Tool Chain for Timed Property Enforcement During eXecution
The TiPEX tool implements the enforcement monitoring algorithms for timed properties proposed in [1]. Enforcement monitors are generated from timed automata specifying timed properties. Such monitors correct input sequences by adding extra delays between events. Moreover, TiPEX also provides modules to generate timed automata from patterns, compose them, and check the class of properties they belong to in order to optimize the monitors. This paper also presents the performance evaluation of TiPEX within some experimental setup.
Génie logiciel [cs.SE]
