Privacy-Preserving Crowd Incident Detection: A Holistic Experimental Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emmanuel Baccelli
Alexandra Danilkina
  • Fonction : Auteur
  • PersonId : 973940
Sebastian Müller
  • Fonction : Auteur
  • PersonId : 973941
Agnès Voisard
  • Fonction : Auteur
  • PersonId : 973942
Matthias Wählisch
  • Fonction : Auteur
  • PersonId : 973943
Detecting dangerous situations is crucial for emergency management. Surveillance systems detect dangerous situations by analyzing crowd dynamics. This paper presents a holis-tic video-based approach for privacy-preserving crowd density estimation. Our experimental approach leverages distributed , on-board pre-processing, allowing privacy as well as the use of low-power, low-throughput wireless communications to interconnect cameras. We developed a multi-camera grid-based people counting algorithm which provides the density per cell for an overall view on the monitored area. This view comes from a merger of infrared and Kinect camera data. We describe our approach using a layered model for data aggregation and abstraction together with a work-flow model for the involved software components, focusing on their functionality. The power of our approach is illustrated through the real-world experiment that we carried out at the Schönefeld airport in the city of Berlin.
em_safest_2015.pdf (968.96 Ko) Télécharger le fichier
hal-01244673 , version 1 (16-12-2015)
  • HAL Id : hal-01244673 , version 1
Emmanuel Baccelli, Alexandra Danilkina, Sebastian Müller, Agnès Voisard, Matthias Wählisch. Privacy-Preserving Crowd Incident Detection: A Holistic Experimental Approach. ACM SIGSPATIAL Workshop on the Use of GIS in Emergency Management (EM-GIS-2015), Nov 2015, Seattle, United States. ⟨hal-01244673⟩
233 Consultations
141 Téléchargements
