Sub-quadratic Decoding of One-point Hermitian Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2015
We present the first two sub-quadratic complexity decoding algorithms for one-point Hermitian codes. The first is based on a fast realisation of the Guruswami–Sudan algorithm by using state-of-the-art algorithms from computer algebra for polynomial-ring matrix minimisation. The second is a Power decoding algorithm: an extension of classical key equation decoding which gives a probabilistic decoding algorithm up to the Sudan radius. We show how the resulting key equations can be solved by the matrix minimisation algorithms from computer algebra, yielding similar asymptotic complexities.
2015_ieee_hermitian.pdf (393.65 Ko) Télécharger le fichier
Origine Fichiers éditeurs autorisés sur une archive ouverte
hal-01245062 , version 1 (17-12-2015)
Johan Sebastian Rosenkilde Nielsen, Peter Beelen. Sub-quadratic Decoding of One-point Hermitian Codes. IEEE Transactions on Information Theory, 2015, 61 (6), pp.3225-3240 ⟨10.1109/TIT.2015.2424415⟩. ⟨hal-01245062⟩
123 Consultations
87 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
