The Design and Formalization of Mezzo, a Permission-Based Programming Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Programming Languages and Systems (TOPLAS) Année : 2016
The programming language Mezzo is equipped with a rich type system that controls aliasing and access to mutable memory. We give a comprehensive tutorial overview of the language. Then, we present a modular formalization of Mezzo's core type system, in the form of a concurrent λ-calculus, which we successively extend with references, locks, and adoption and abandon, a novel mechanism that marries Mezzo's static ownership discipline with dynamic ownership tests. We prove that well-typed programs do not go wrong and are data-race free. Our definitions and proofs are machine-checked.
bpp-mezzo-journal.pdf (1022.32 Ko) Télécharger le fichier
hal-01246534 , version 1 (18-12-2015)
Thibaut Balabonski, François Pottier, Jonathan Protzenko. The Design and Formalization of Mezzo, a Permission-Based Programming Language. ACM Transactions on Programming Languages and Systems (TOPLAS), 2016, 38 (4), pp.94. ⟨10.1145/2837022⟩. ⟨hal-01246534⟩
244 Consultations
294 Téléchargements
