RV-Android: Efficient Parametric Android Runtime Verification, a Brief Tutorial - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
RV-Android is a new freely available open source runtime library for monitoring formal safety properties on Android. RV-Android uses the commercial RV-Monitor technology as its core monitoring library generation technology, allowing for the verification of safety properties during execution and operating entirely in userspace with no kernel or operating system modifications required. RV-Android improves on previous Android monitoring work by replacing the JavaMOP framework with RV-Monitor, a more advanced monitoring library generation tool with core algorithmic improvements that greatly improve resource consumption , e and battery life considerations. We demonstrate the developer usage of RV-Android with the standard Android build process, using instrumentation mechanisms e↵ective on both Android binaries and source code. Our method allows for both property development and advanced application testing through runtime verification. We showcase the user frontend of RV-Monitor, which is available for public demo use and requires no knowledge of RV concepts. We explore the extra expres-siveness the MOP paradigm provides over simply writing properties as aspects through two sample security properties, and show an example of a real security violation mitigated by RV-Android on-device. Lastly, we propose RV as an extension to the next-generation Android permissions system debuting in Android M.
rv15-3.pdf (1 Mo) Télécharger le fichier
hal-01248350 , version 1 (28-12-2015)
Philip Daian, Yliès Falcone, Patrick Meredith, Traian Florin Serbanuta, Shin’ichi Shiriashi, et al.. RV-Android: Efficient Parametric Android Runtime Verification, a Brief Tutorial. 6th International Conference, RV 2015, Vienna, Austria, September 22-25, 2015. Proceedings, Sep 2015, Vienne, Austria. pp.16, ⟨10.1007/978-3-319-23820-3_24⟩. ⟨hal-01248350⟩
174 Consultations
419 Téléchargements
