Datalog Rewritings of Regular Path Queries using Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2015
Nadime Francis
Luc Segoufin
We consider query answering using views on graph databases, i.e. databases structured as edge-labeled graphs. We mainly consider views and queries specified by Regular Path Queries (RPQ). These are queries selecting pairs of nodes in a graph database that are connected via a path whose sequence of edge labels belongs to some regular language. We say that a view V determines a query Q if for all graph databases D, the view image V(D) always contains enough information to answer Q on D. In other words, there is a well defined function from V(D) to Q(D). Our main result shows that when this function is monotone, there exists a rewriting of Q as a Datalog query over the view instance V(D). In particular the rewriting query can be evaluated in time polynomial in the size of V(D). Moreover this implies that it is decidable whether an RPQ query can be rewritten in Datalog using RPQ views.
views-rpq-datalog.pdf (435.46 Ko) Télécharger le fichier
hal-01248391 , version 1 (25-12-2015)
  • HAL Id : hal-01248391 , version 1
Nadime Francis, Luc Segoufin, Cristina Sirangelo. Datalog Rewritings of Regular Path Queries using Views. Logical Methods in Computer Science, 2015, 11 (4). ⟨hal-01248391⟩
108 Consultations
85 Téléchargements
