Embedded P.E.M. fuel cell stack nonlinear observer by means of a Takagi-Sugeno approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Studies in Informatics and Control Année : 2015
Lotfi Belkoura
Adnan A.J Jouni
  • Fonction : Auteur
  • PersonId : 938208
This paper deals with the design of a nonlinear state observer for parameters within the gas transfer part of a fuel cell stack and its implementation on a small scaled embedded system. The fuel cell stack is of a proton exchange membrane type, with parameters specific to vehicle applications. The observer is afterwards applied on a small scale embedded board. In order to validate the embedded observer, a real time hardware in the loop testing is done using a cosimulation between the embedded observer and the professional simulation software AMESim, linked with Simulink on a windows platform. To act upon the nonlinear character of the system, a Takagi-Sugeno approach is implemented, where the premise variables are unmeasurable. The procedure applies Lyapunov stability theory and by demanding bounded stability instead of asymptotic one, the algorithm manages to eliminate the need for Lipschitz constants.
Mots clés
Automatique
Journal_SIC_S-Olteanu.pdf (747.3 Ko) Télécharger le fichier
hal-01248947 , version 1 (29-12-2015)
  • HAL Id : hal-01248947 , version 1
Severus Constantin Olteanu, Abdel Aitouche, Lotfi Belkoura, Adnan A.J Jouni. Embedded P.E.M. fuel cell stack nonlinear observer by means of a Takagi-Sugeno approach. Studies in Informatics and Control, 2015, 24 (1). ⟨hal-01248947⟩
213 Consultations
401 Téléchargements
