New interface
Journal articles
On the ternary spatial relation "Between"
Abstract : The spatial relation "between" is a notion which is intrinsically both fuzzy and contextual, and depends, in particular, on the shape of the objects. The literature is quite poor on this and the few existing definitions do not take into account these aspects. In particular, an object B that is in a concavity of an object A1 not visible from an object A2 is considered between A1 and A2 for most definitions, which is counter intuitive. Also, none of the definitions deal with cases where one object is much more elongated than the other. Here, we propose definitions which are based on convexity, morphological operators, and separation tools, and a fuzzy notion of visibility. They correspond to the main intuitive exceptions of the relation. We distinguish between cases where objects have similar spatial extensions and cases where one object is much more extended than the other. Extensions to cases where objects, themselves, are fuzzy and to three-dimensional space are proposed as well. The original work proposed in this paper covers the main classes of situations and overcomes the limits of existing approaches, particularly concerning nonvisible concavities and extended objects. Moreover, the definitions capture the intrinsic imprecision attached to this relation. The main proposed definitions are illustrated on real data from medical images.
Document type :
Journal articles
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01251251
Contributor : Olivier Colliot Connect in order to contact the contributor
Submitted on : Tuesday, January 5, 2016 - 7:46:59 PM
Last modification on : Friday, November 4, 2022 - 6:54:06 PM
Long-term archiving on: : Thursday, April 7, 2016 - 3:41:51 PM
File
bloch_ieee_tsmcb2006_preprint....
Identifiers
Collections
Citation
Isabelle Bloch, Olivier Colliot, Roberto M. Cesar. On the ternary spatial relation "Between". IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics, 2006, 36 (2), pp.312-327. ⟨10.1109/TSMCB.2005.857095⟩. ⟨hal-01251251⟩
Share
Metrics
Record views
75
Files downloads
160
