On the ternary spatial relation "Between" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics Année : 2006
The spatial relation "between" is a notion which is intrinsically both fuzzy and contextual, and depends, in particular, on the shape of the objects. The literature is quite poor on this and the few existing definitions do not take into account these aspects. In particular, an object B that is in a concavity of an object A1 not visible from an object A2 is considered between A1 and A2 for most definitions, which is counter intuitive. Also, none of the definitions deal with cases where one object is much more elongated than the other. Here, we propose definitions which are based on convexity, morphological operators, and separation tools, and a fuzzy notion of visibility. They correspond to the main intuitive exceptions of the relation. We distinguish between cases where objects have similar spatial extensions and cases where one object is much more extended than the other. Extensions to cases where objects, themselves, are fuzzy and to three-dimensional space are proposed as well. The original work proposed in this paper covers the main classes of situations and overcomes the limits of existing approaches, particularly concerning nonvisible concavities and extended objects. Moreover, the definitions capture the intrinsic imprecision attached to this relation. The main proposed definitions are illustrated on real data from medical images.
bloch_ieee_tsmcb2006_preprint.pdf (700.23 Ko) Télécharger le fichier
hal-01251251 , version 1 (05-01-2016)
Paternité
Isabelle Bloch, Olivier Colliot, Roberto M. Cesar. On the ternary spatial relation "Between". IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics, 2006, 36 (2), pp.312-327. ⟨10.1109/TSMCB.2005.857095⟩. ⟨hal-01251251⟩
84 Consultations
206 Téléchargements
