An Oracle Inequality for Quasi-Bayesian Non-Negative Matrix Factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Methods of Statistics Année : 2017
The aim of this paper is to provide some theoretical understanding of Bayesian non-negative matrix factorization methods. We derive an oracle inequality for a quasi-Bayesian estimator. This result holds for a very general class of prior distributions and shows how the prior affects the rate of convergence. We illustrate our theoretical results with a short numerical study along with a discussion on existing implementations .
main_rev.pdf (272.64 Ko) Télécharger le fichier
hal-01251878 , version 1 (06-01-2016)
hal-01251878 , version 2 (07-06-2016)
hal-01251878 , version 3 (25-08-2016)
hal-01251878 , version 4 (26-06-2018)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-01251878 , version 3
Pierre Alquier, Benjamin Guedj. An Oracle Inequality for Quasi-Bayesian Non-Negative Matrix Factorization. Mathematical Methods of Statistics, 2017. ⟨hal-01251878v3⟩
1657 Consultations
826 Téléchargements
