Abstract : The Knuth-Bendix method takes in argument a finite set of equations and rewrite rules and, when it succeeds, returns an algorithm to decide if a term is equivalent to another modulo these equations and rules. In this paper, we design a similar method that takes in argument a finite set of rewrite rules and, when it succeeds, returns an algorithm to decide not equivalence but reachability modulo these rules, that is if a term reduces to another. As an application, we give new proofs of the decidability of reachability in finite ground rewrite systems and in pushdown systems.
