A Completion Method to Decide Reachability in Rewrite Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Knuth-Bendix method takes in argument a finite set of equations and rewrite rules and, when it succeeds, returns an algorithm to decide if a term is equivalent to another modulo these equations and rules. In this paper, we design a similar method that takes in argument a finite set of rewrite rules and, when it succeeds, returns an algorithm to decide not equivalence but reachability modulo these rules, that is if a term reduces to another. As an application, we give new proofs of the decidability of reachability in finite ground rewrite systems and in pushdown systems.
pkb.pdf (238.89 Ko) Télécharger le fichier
hal-01252138 , version 1 (07-01-2016)
Guillaume Burel, Gilles Dowek, Ying Jiang. A Completion Method to Decide Reachability in Rewrite Systems. International Symposium on Frontiers of Combining Systems FroCoS'15, Sep 2015, Wroclaw, Poland. pp.205-219, ⟨10.1007/978-3-319-24246-0_13⟩. ⟨hal-01252138⟩
103 Consultations
132 Téléchargements
