Carrier Frequency Offset Estimation Based on Circular Harmonic Expansion for Optical Coherent M-QAM Communication Systems
Circular harmonic expansion-based carrier frequency offset estimation is investigated for optical M-QAM communication systems. The proposed method, combined with a gradient-descent algorithm, shows better performance compared to already proposed VVMFOE and 4th power methods.
