Carrier Frequency Offset Estimation Based on Circular Harmonic Expansion for Optical Coherent M-QAM Communication Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Circular harmonic expansion-based carrier frequency offset estimation is investigated for optical M-QAM communication systems. The proposed method, combined with a gradient-descent algorithm, shows better performance compared to already proposed VVMFOE and 4th power methods.
OECC2015_Hien_final.pdf (102.48 Ko) Télécharger le fichier
hal-01316911 , version 1 (17-05-2016)
Trung Hien Nguyen, Michel Joindot, Mathilde Gay, Laurent Bramerie, Jean-Claude Simon, et al.. Carrier Frequency Offset Estimation Based on Circular Harmonic Expansion for Optical Coherent M-QAM Communication Systems. 20th Opto-Electronics and Communications Conference (OECC 2015), Jun 2015, Shanghai, China. pp.1-3, ⟨10.1109/OECC.2015.7340175⟩. ⟨hal-01316911⟩
623 Consultations
858 Téléchargements
