New interface
Reports (Research report)
Indicateurs de raffinement pour une paramétrisation optimale dans l'estimation de coefficients hydrogéologiques
Abstract : We identify simultaneously storage and hydraulic transmissivity coefficients in groundwater flow governed by a linear parabolic equation. Both parameters are assumed to be functions piecewise constant in space. The unknowns are the coefficient values as well as the geometry of the zones where these coefficients are constant. This problem is formulated as minimizing a least-square function calculating the difference between measurements and the corresponding quantities computed with the current parameters values.The main point of this paper is to construct an adaptative parameterization technique guided by refinement indicators.
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01254165
Contributor : Jérôme Jaffré Connect in order to contact the contributor
Submitted on : Monday, January 11, 2016 - 6:50:23 PM
Last modification on : Wednesday, October 26, 2022 - 8:14:26 AM
Long-term archiving on: : Tuesday, April 12, 2016 - 11:41:06 AM
File
RR8791.pdf
Identifiers
  • HAL Id : hal-01254165, version 1
Collections
Citation
Mohamed Hedi Riahi, Hend Ben Ameur, Rachida Bouhlila, Jérôme Jaffré. Indicateurs de raffinement pour une paramétrisation optimale dans l'estimation de coefficients hydrogéologiques. [Rapport de recherche] RR-8791, INRIA Paris-Rocquencourt; Université de Tunis El Manar, ENIT-LAMSIN. 2015, pp.30. ⟨hal-01254165⟩
Share
Metrics
Record views
303
Files downloads
141
