Týr: Efficient Transactional Storage for Data-Intensive Applications
Týr: Stockage Massif Transactionnel à Hautes-Performances
As the computational power used by large-scale applications increases, the amount of data they need to manipulate tends to increase as well. A wide range of such applications requires robust and flexible storage support for atomic, durable and concurrent transactions. Historically, databases have provided the de facto solution to transactional data management, but they have forced applications to drop control over data layout and access mechanisms, while remaining unable to meet the scale requirements of Big Data. More recently, key-value stores have been introduced to address these issues. However, this solution does not provide transactions, or only restricted transaction support, compelling users to carefully coordinate access to data in order to avoid race conditions, partial writes, overwrites, and other hard problems that cause erratic behaviour. We argue there is a gap between existing storage solutions and application requirements that limits the design of transaction-oriented data-intensive applications. In this paper we introduce Týr, a massively parallel distributed transactional blob storage system. A key feature behind Týr is its novel multi-versioning management designed to keep the metadata overhead as low as possible while still allowing fast queries or updates and preserving transaction semantics. Its share-nothing architecture ensures minimal contention and provides low latency for large numbers of concurrent requests. Týr is the first blob storage system to provide sequential consistency and high throughput, while enabling unforeseen transaction support. Experiments with a real-life application from the CERN LHC show Týr throughput outperforming state-of-the-art solutions by more than 100%.
À mesure que la puissance de calcul utilisée par des applications à grande échelle augmente, le volume de données qu’elles manipulent tend à augmenter également. Une grande partie de ces applications nécessite un système de stockage robuste et flexible permettant l’exécution de transactions de manière concurrente. Antérieurement, les bases de données furent la solution de facto pour la gestion des données transactionnelles, mais elles empêchent les applications de contrôler l’organisation du stockage des données ainsi que l’accés à ces données, tout en restant incapables de répondre aux contraintes posées par les données massives. Plus récemment, des systèmes de stockage clé-valeur ont été créés pour répondre à cette problématique. Cependant, ces solutions ne fournissent pas de support des transactions, ou seulement un support partiel, imposant aux utilisateurs de coordonner avec soin l’accès aux données afin d’éviter tout état de concurrence, écritures partielles, surécritures, ainsi que d’autres problèmes à l’origine d’un comportement erratique des applications. Nous soutenons qu’il existe un fossé entre les solutions de stockage actuelles et les besoins des utilisateurs, ce qui limite la conception des applications transactionnelles gérant des volumes massifs de données. Dans ce document, nous présentons Týr, un système de stockage de blobs distribué et transactionnel. Une des caractéristiques principales de Týr est sa gestion des versions novatrice conçue pour permettre un accès rapide tant en lecture qu’en écriture aux données tout en gardant une sémantique transactionnelle et en nécessitant une faible surcharge de métadonnées. Son architecture décentralisée garantit une contention minimale et permet une faible latence avec un nombre important de requêtes concurrentes. Týr est le permier système de stockage de blobs à fournir à la fois une consistence séquentielle et un débit élevé, tout en apportant le support des transactions. Les expériences réalisées avec une application réelle du CERN LHC montrent que le débit de Týr surpasse celui des solutions actuelles de plus de 100%.
