Musical Composition with Stochastic Context-Free Grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we discuss the design of a generator of musical sequences for the purpose of aiding musicians in their compositional work. A series of steps were abstracted to reflect composition as a sequential flow of data refination; also each step involved in this process was modeled to gain each one of their functions. Specifically, in the case of the main structure of the suggestion a stochastic context-free grammar was developed to generate harmonic progressions, in the case of rhythms a probabilistic model based on accents was also developed, and finally, to state individual notes of the suggestion another probabilistic model based in the dissonance of intervals was used. Each one of these models were structured upon J.S. Bach's rules of homophonic composition as this was the target musical genre of the work
MusicPerchySarria-FinalCameraRead.pdf (177.72 Ko) Télécharger le fichier
hal-01257155 , version 1 (15-01-2016)
  • HAL Id : hal-01257155 , version 1
Salim Perchy, Gerardo Sarria. Musical Composition with Stochastic Context-Free Grammars. 8th Mexican International Conference on Artificial Intelligence (MICAI 2009), Nov 2009, Guanajuato, Mexico. ⟨hal-01257155⟩
203 Consultations
699 Téléchargements
