Stability Analysis for Time-Varying Systems with Delay using Linear Lyapunov Functionals and a Positive Systems Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2016
We prove stability of time-varying systems with delays, using linear Lyapunov functionals and positive systems, and we provide robustness of the stability with respect to multiplicative uncertainty in the vector fields. We allow cases where the delay may be unknown, and where the vector fields defining the systems are not necessarily bounded. We illustrate our work using a chain of integrators and other examples.
Automatique
4June2015.pdf (439 Ko) Télécharger le fichier
hal-01257336 , version 1 (16-01-2016)
Frédéric Mazenc, Michael Malisoff. Stability Analysis for Time-Varying Systems with Delay using Linear Lyapunov Functionals and a Positive Systems Approach. IEEE Transactions on Automatic Control, 2016, 61 (3), pp.771-776. ⟨10.1109/TAC.2015.2446111⟩. ⟨hal-01257336⟩
270 Consultations
361 Téléchargements
