Abstract : Continuous-discrete systems can occur when the plant state evolves in continuous time but the output values are only available at discrete instants. Continuous-discrete observers have the valuable property that the observation error between the true state of the system and the observer state converges to zero in a uniform way. The design of continuous-discrete observers can often be done by building framers, which provide componentwise upper and lower bounds for the plant state. This paper is a tutorial on these approaches, highlighting recent results in the literature, and also providing previously unpublished, original results which are not being simultaneously submitted elsewhere.
