Enabling the Reuse of Stored Model Transformations Through Annotations
With the increasing adoption of MDE, model transformations , one of its core concepts together with metamodeling, stand out as a valuable asset. Therefore, a mechanism to annotate and store existing model transformations appears as a critical need for their efficient exploitation and reuse. Unfortunately, although several reuse mechanisms have been proposed for software artifacts in general and models in particular , none of them is specially tailored to the domain of model transformations. In order to fill this gap, we present here such a mechanism. Our approach is composed by two elements 1) a new DSL specially conceived for describing model transformations in terms of their functional and non-functional properties 2) a semi-automatic process for annotating and querying (repositories of) model transformations using as criteria the properties of our DSL. We validate the feasibility of our approach through a prototype implementation that integrates our approach in a GitHub repository.
Génie logiciel [cs.SE]
