Uniformly accurate time-splitting methods for the semiclassical linear Schrödinger equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2019
This article is devoted to the construction of numerical methods which remain insensitive to the smallness of the semiclassical parameter for the linear Schrödinger equation in the semiclassical limit. We specifically analyse the convergence behavior of the first-order splitting. Our main result is a proof of uniform accuracy. We illustrate the properties of our methods with simulations.
UAmethodPart2.pdf (222.77 Ko) Télécharger le fichier
hal-01257753 , version 1 (18-01-2016)
hal-01257753 , version 2 (11-10-2018)
hal-01257753 , version 3 (26-08-2020)
Philippe Chartier, Loïc Le Treust, Florian Méhats. Uniformly accurate time-splitting methods for the semiclassical linear Schrödinger equation. ESAIM: Mathematical Modelling and Numerical Analysis, 2019, 53 (2), pp.443-473. ⟨10.1051/m2an/2018060⟩. ⟨hal-01257753v1⟩
577 Consultations
190 Téléchargements
