On local optima in minimum time control of the restricted three-body problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
The structure of local minima for time minimization in the controlled three-body problem is studied. Several homotopies are systematically used to unfold the structure of these local minimizers, and the resulting singularity of the path associated with the value function is analyzed numerically.
hal-01260120 , version 1 (21-01-2016)
Jean-Baptiste Caillau, Ariadna Farrés. On local optima in minimum time control of the restricted three-body problem. Bernard Bonnard; Monique Chyba. Recent Advances in Celestial and Space Mechanics, 23, Springer, pp.209 - 302, 2016, Mathematics for Industry, 978-3-319-27464-5. ⟨10.1007/978-3-319-27464-5⟩. ⟨hal-01260120⟩
146 Consultations
0 Téléchargements
