Image Stitching Based Measurements of Medical Screws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Image stitching is a method that forms a bigger image out of two or more smaller images with a certain overlap in their field-of-view. Usage of this technique is present in photography, medical imaging and other fields as well. The potential for using image stitching for measurement purposes in industrial applications has not been investigated as thoroughly, but it is receiving more attention. This paper examines the possibility for creating a machine vision-based measurement system that employs commercially available image-stitching platforms for measuring the length of long medical screws. Three methodologies were tested for performing medical screw measurements and this paper summarizes the findings of the image-stitching approach.
978-3-662-45586-9_10_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01260734 , version 1 (22-01-2016)
Paternité
Zoran Cenev, Timo Prusi, Reijo Tuokko. Image Stitching Based Measurements of Medical Screws. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. pp.69-78, ⟨10.1007/978-3-662-45586-9_10⟩. ⟨hal-01260734⟩
78 Consultations
95 Téléchargements
