Process Module Construction Kit for Modular Micro Assembly Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The production environment in Europe is characterized by a number of different challenges. Production volumes are hardly predictable due to the turbulent market [1]. Product life cycles become increasingly shorter [2]. Customers demand more individual and customized products, which leads to increasingly diversified product pallets [3]. The occurrence of changes on product and process, even for running productions, increases continuously [4]. At the same time the field of tension between assurance of quality, reduction of lead times and reduction of cost remains present [5].
978-3-662-45586-9_16_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01260748 , version 1 (22-01-2016)
Paternité
Raphael Adamietz, Tobias Iseringhausen, Alexander Verl. Process Module Construction Kit for Modular Micro Assembly Systems. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. pp.126-132, ⟨10.1007/978-3-662-45586-9_16⟩. ⟨hal-01260748⟩
121 Consultations
158 Téléchargements
