A Positive and Entropy-Satisfying Finite Volume Scheme for the Baer-Nunziato Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Jean-Marc Hérard
EDF
Khaled Saleh
Nicolas Seguin
We present a relaxation scheme for approximating the entropy dissipating weak solutions of the Baer-Nunziato two-phase flow model. This relaxation scheme is straightforwardly obtained as an extension of the relaxation scheme designed in the reference [16] for the isentropic Baer-Nunziato model and consequently inherits its main properties. Up to our knowledge, this is the only existing scheme for which the approximated phase fractions, phase densities and phase pressures are proven to remain positive without any restrictive condition other than a classical fully computable CFL condition. It is also the only scheme for which a discrete entropy inequality is proven, under a CFL condition derived from the natural sub-characteristic condition associated with the relaxation approximation. These two properties of the numerical scheme (discrete positivity and entropy inequality) are satisfied for any admissible equation of state. We provide a numerical study for the convergence of the approximate solutions towards some exact Riemann solutions. The numerical simulations show a higher precision and a more reduced computational cost (for comparable accuracy) than standard numerical schemes used in the nuclear industry. We also assess the good behavior of the scheme when approximating vanishing phase solutions.
BN_Energie_CHSS.pdf (1.3 Mo) Télécharger le fichier
hal-01261458 , version 1 (26-01-2016)
hal-01261458 , version 2 (10-02-2016)
hal-01261458 , version 3 (27-10-2016)
hal-01261458 , version 4 (27-10-2016)
Paternité - Pas d'utilisation commerciale - Pas de modification
Frédéric Coquel, Jean-Marc Hérard, Khaled Saleh, Nicolas Seguin. A Positive and Entropy-Satisfying Finite Volume Scheme for the Baer-Nunziato Model. 2016. ⟨hal-01261458v1⟩
Collections
UPMC LJLL
1881 Consultations
248 Téléchargements
