Trust Driven Strategies for Privacy by Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we describe a multi-step approach to privacy by design. The main design step is the choice of the types of trust that can be accepted by the stakeholders, which is a key driver for the construction of an acceptable architecture. Architectures can be initially defined in a purely informal way and then mapped into a formal dedicated model. A tool integrating the approach can be used by designers to build and verify architectures. We apply the approach to a case study, an electronic toll pricing system, and show how different solutions can be suggested to the designer depending on different trust assumptions.
337890_1_En_5_Chapter.pdf (793.71 Ko) Télécharger le fichier
hal-01262365 , version 1 (14-12-2016)
Paternité
Thibaud Antignac, Daniel Le Métayer. Trust Driven Strategies for Privacy by Design. 9th IFIP International Conference on Trust Management (TM), May 2015, Hamburg, Germany. pp.60-75, ⟨10.1007/978-3-319-18491-3_5⟩. ⟨hal-01262365⟩
364 Consultations
182 Téléchargements
