New interface
Journal articles
Observability under sampling for nonlinear systems
Abstract : A previous article has investigated the problem of the preservation of the observability under sampling in the framework of compact manifolds. A natural generalization of the cited result would be to extend it to the systems globally Lipschitzian defined on non compact manifolds. A simple representative of this class of systems is constituted by the set of bilinear systems, for this particular class of systems the preservation of the property of observability has been shown in a previous work. In this paper, we deal with the preservation of the observability under sampling for globally Lipschitzian systems defined on $\mathbb{R}^n$
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01264249
Contributor : Jean-Claude Vivalda Connect in order to contact the contributor
Submitted on : Friday, January 29, 2016 - 9:11:49 AM
Last modification on : Friday, July 8, 2022 - 10:10:33 AM
Links full text
Identifiers
Collections
Citation
Sabeur Ammar, Majid Massaoud, Jean-Claude Vivalda. Observability under sampling for nonlinear systems. Asian Journal of Control, 2016, 18 (4), pp.10. ⟨10.1002/asjc.1284⟩. ⟨hal-01264249⟩
Share
Metrics
Record views
99
