Spectral rigidity of group actions on homogeneous spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Actions of a locally compact group G on a measure space X give rise to unitary representations of G on Hilbert spaces. We review results on the rigidity of these actions from the spectral point of view, that is, results about the existence of a spectral gap for associated averaging operators and their consequences. We will deal both with spaces X with an infinite measure as well as with spaces with an invariant probability measure. The spectral gap property has several striking applications to group theory, geometry, ergodic theory, operator algebras, graph theory, theoretical computer science, etc.
Bekka-GroupActions-VersionArXiv3.pdf (487.93 Ko) Télécharger le fichier
hal-01270244 , version 1 (08-02-2016)
hal-01270244 , version 2 (10-05-2016)
Bachir Bekka. Spectral rigidity of group actions on homogeneous spaces. 2016. ⟨hal-01270244v1⟩
436 Consultations
298 Téléchargements
