StreamDM: Advanced Data Mining in Spark Streaming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Albert Bifet
Jianfeng Qian
  • Fonction : Auteur
  • PersonId : 976396
Guangjian Tian
  • Fonction : Auteur
  • PersonId : 976397
Wei Fan
Real-time analytics are becoming increasingly important due to the large amount of data that is being created continuously. Drawing from our experiences at Huawei Noah's Ark Lab, we present and demonstrate here StreamDM, a new open source data mining and machine learning library, designed on top of Spark Streaming, an extension of the core Spark API that enables scalable stream processing of data streams. StreamDM is designed to be easily extended and used, either practitioners, developers, or researchers, and is the first library to contain advanced stream mining algorithms for Spark Streaming .
bifet2015streamdm.pdf (386.16 Ko) Télécharger le fichier
hal-01270606 , version 1 (08-02-2016)
Albert Bifet, Silviu Maniu, Jianfeng Qian, Guangjian Tian, Cheng He, et al.. StreamDM: Advanced Data Mining in Spark Streaming. International Conference on Data Mining Workshops (ICDMW), IEEE, Nov 2015, Atlantic City, NJ, United States. ⟨10.1109/ICDMW.2015.140⟩. ⟨hal-01270606⟩
479 Consultations
975 Téléchargements
