The assessment of BitTorrent's performance using SDN in a Mesh topology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2015
– The basis of this paper is grounded upon the theoretical assumption, which states that the integration of BitTorrent with Software-defined Networks (SDNs) will degrade the performance of BitTorrent, instead of improving it. This was further evaluated by emulating this experiment on a Ring topology to verify the results. The experimental results, however, showed an unexpected behavior wherein BitTorrent outperformed under a SDN. This objective of this paper is to re-evaluate the behavior of BitTorrent in a Mesh topology instead. We have run 12 BitTorrent clients in an emulated SDN Mesh topology using Mininet and varied the virtual topology periodically by taking one link down at a time from the topology. The experimental results show when the logical topology changed periodically the performance is worse than when the topology is static for BitTorrent.
07333294.pdf (262.94 Ko) Télécharger le fichier
hal-01274346 , version 1 (23-02-2016)
Mandeep Kaur Guraya, Rupinder Singh Bajwa, Damian Vicino, Chung-Horng Lung. The assessment of BitTorrent's performance using SDN in a Mesh topology. The 6th International Conference On Network of the Future, Sep 2015, Montreal, QC, Canada. , 2015, ⟨10.1109/NOF.2015.7333294⟩. ⟨hal-01274346⟩
170 Consultations
319 Téléchargements
