Multi-platform Semantic Representation of Interactive 3D Content - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a semantic approach to building multi-platform 3D content is proposed. The presented solution is intended to enable flexible and efficient creation of 3D presentations covering a wide range of target platforms – visualisation tools, content representation languages and programming libraries. Referring to the semantics of particular content elements can facilitate conceptual knowledge-based content creation at arbitrarily high levels of abstraction, and it can improve indexing, searching and analysis of 3D content in a variety of application domains on the web.
978-3-642-54734-8_8_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01274753 , version 1 (16-02-2016)
Paternité
Jakub Flotyński, Krzysztof Walczak. Multi-platform Semantic Representation of Interactive 3D Content. 5th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2014, Costa de Caparica, Portugal. pp.63-72, ⟨10.1007/978-3-642-54734-8_8⟩. ⟨hal-01274753⟩
33 Consultations
80 Téléchargements
