Distributed Smart Metering by Using Power Electronics Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The main objective of this paper is to develop a monitor system implemented in existing power electronics equipment. The proposed algorithm is integrated in a previously developed Photovoltaic Array Emulator with the principal aim of monitoring important quality parameters that will be sent to a central repository (by using UDP protocol), where they will be available as Open data.
978-3-642-54734-8_32_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01274788 , version 1 (16-02-2016)
Paternité
Francisco M. Navas-Matos, Sara Polo-Gallego, Enrique Romero-Cadaval, Maria Isabel Milanés-Montero. Distributed Smart Metering by Using Power Electronics Systems. 5th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2014, Costa de Caparica, Portugal. pp.289-296, ⟨10.1007/978-3-642-54734-8_32⟩. ⟨hal-01274788⟩
25 Consultations
95 Téléchargements
