An Innovator Nonintrusive Method for Disaggregating and Identifying Two Simultaneous Household Loads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
At the present time the monitoring systems are important in some areas, such as electric power supply industry and household environment because they provide useful information to energy storage and management tasks. A new nonintrusive monitoring method is proposed in this paper and it is able to disaggregate and identify two loads working simultaneously using a single measuring sensor and a least squares regression algorithm based on discrete form of the S-Transform.
978-3-642-54734-8_33_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01274980 , version 1 (16-02-2016)
Paternité
Máximo Pérez-Romero, Enrique Romero-Cadaval, Adolfo Lozano-Tello, João Martins, Rui Lopes. An Innovator Nonintrusive Method for Disaggregating and Identifying Two Simultaneous Household Loads. 5th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2014, Costa de Caparica, Portugal. pp.297-304, ⟨10.1007/978-3-642-54734-8_33⟩. ⟨hal-01274980⟩
73 Consultations
125 Téléchargements
