Hasse-Weil Bound for Additive Cyclic Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We obtain a bound on the minimum distance of additive cyclic codes via number of rational points on certain algebraic curves over finite fields. This is an extension of the analogous bound in the case of classical cyclic codes. Our result seems to be the only general bound on such codes aside from Bierbrauer's BCH bound.
wcc15-mo3-1.pdf (253.08 Ko) Télécharger le fichier
hal-01275733 , version 1 (18-02-2016)
  • HAL Id : hal-01275733 , version 1
Cem Güneri, Ferruh Özbudak, Fundä Ozdemir. Hasse-Weil Bound for Additive Cyclic Codes. WCC2015 - 9th International Workshop on Coding and Cryptography 2015, Anne Canteaut, Gaëtan Leurent, Maria Naya-Plasencia, Apr 2015, Paris, France. ⟨hal-01275733⟩
Collections
WCC2015
32 Consultations
218 Téléchargements
