Cover-Free Codes and Separating System Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We discover some important properties of cover-free (CF) codes, separating system (SS) codes and completely separating system (CSS) codes connected with the concept of constant weight CF codes. New upper and lower bounds on the rate of CF and SS codes based on the known results for CF and CSS codes are obtained. Tables of numerical values for the improved upper and lower bounds are presented.
wcc15-fr2-3.pdf (310.42 Ko) Télécharger le fichier
hal-01276696 , version 1 (19-02-2016)
  • HAL Id : hal-01276696 , version 1
A.G. d'Yachkov, I.V. Vorobyev, N.A. Polyanskii, V.Yu. Shchukin. Cover-Free Codes and Separating System Codes. The 9th International Workshop on Coding and Cryptography 2015 WCC2015, Anne Canteaut, Gaëtan Leurent, Maria Naya-Plasencia, Apr 2015, Paris, France. ⟨hal-01276696⟩
Collections
WCC2015
24 Consultations
216 Téléchargements
