Abstract : This work is motivated by the challenging problem of the computer-aided generation of approximations (viewed as a series of transformations) of partial derivative equations. In this framework, the approximations posed over complex settings are incrementally constructed by extending an approximation posed on a simple setting and combining these extensions. In order to formalize these extensions and their combination, we introduce a class of rewriting strategies, called context-embedding iterative strategies (CE-strategies, for short). Roughly speaking, the class of CE-strategies is constructed by means of adding contexts and an iteration operator allowing the definition of recursive strategies. We show that the class of CE-strategies is closed under combination with respect to a correctness-completeness criterion. It turns out that the class CE-strategies enjoy nice algebraic properties, namely, the combination is associative, has a neutral element, and all the elements are idempotents.
