Hydrodynamic limit of granular gases to pressureless Euler in dimension 1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quarterly of Applied Mathematics Année : 2017
We investigate the behavior of granular gases in the limit of small Knudsen number, that is very frequent collisions. We deal with the strongly inelastic case, in one dimension of space and velocity. We are able to prove the convergence toward the pressureless Euler system. The proof relies on dispersive relations at the kinetic level, which leads to the so-called Oleinik property at the limit.
JabinReyGranular4.pdf (439.59 Ko) Télécharger le fichier
hal-01279961 , version 1 (28-02-2016)
Paternité - Pas d'utilisation commerciale
Pierre-Emmanuel Jabin, Thomas Rey. Hydrodynamic limit of granular gases to pressureless Euler in dimension 1. Quarterly of Applied Mathematics, 2017, 75, pp.155-179. ⟨10.1090/qam/1442⟩. ⟨hal-01279961⟩
688 Consultations
64 Téléchargements
