On board System for flight control of a small UAV - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present the design of an autopilot embedded system applied to control a four rotor mini helicopter, called X4-flyer. The main goal is to achieve a stable flight, controlling the vehicle attitude; this is done using two control strategies: a linear PD control and nonlinear nested saturations control. The onboard system uses a simplified parallel processing architecture and the main processor performs a multitasking program to handle the data acquisition, control law computation, and actuators correction to get the desired set point. Real time experiments show that the autopilot is a platform relievable with low cost components.
Fichier non déposé
hal-01280315 , version 1 (29-02-2016)
  • HAL Id : hal-01280315 , version 1
David Lara, Gerardo Romero, Ramiro Ibarra, Anand Sanchez, Claude Pegard. On board System for flight control of a small UAV . World Automation Congress (WAC), Jun 2012, Puerto Vallarta, Mexico, France. pp.6. ⟨hal-01280315⟩
31 Consultations
0 Téléchargements
