Phase transitions in the Potts model on complex networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Condensed Matter Physics Année : 2013
The Potts model is one of the most popular spin models of statistical physics. The prevailing majority of work done so far corresponds to the lattice version of the model. However, many natural or man-made systems are much better described by the topology of a network. We consider the q-state Potts model on an uncorrelated scale-free network for which the node-degree distribution manifests a power-law decay governed by the exponent lambda. We work within the mean-field approximation, since for systems on random uncorrelated scale-free networks this method is known to often give asymptotically exact results. Depending on particular values of q and lambda one observes either a first-order or a second-order phase transition or the system is ordered at any finite temperature. In a case study, we consider the limit q = 1 (percolation) and find a correspondence between the magnetic exponents and those describing percolation on a scale-free network. Interestingly, logarithmic corrections to scaling appear at lambda = 4 in this case.
CMP_16_23602_2013.pdf (738.71 Ko) Télécharger le fichier
hal-01280987 , version 1 (03-03-2017)
Marjana Krasnytska, Bertrand Berche, Yurij Holovatch. Phase transitions in the Potts model on complex networks. Condensed Matter Physics, 2013, 16 (2), ⟨10.5488/CMP.16.23602⟩. ⟨hal-01280987⟩
69 Consultations
54 Téléchargements
