Industrial Wireless IP-based Cyber Physical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the IEEE Année : 2016
Industrial control systems have traditionally been built around dedicated wired solutions. The requirements of flexibility, mobility, and cost have created a strong push toward wireless solutions, preferably solutions requiring low power. Simultaneously, the increased need for interoperability and integration with the wider Internet made a transition to IP-based communication unavoidable. Following these trends, we survey 6TiSCH, the emerging family of standards for IP-based industrial communication over low-power and lossy networks. We describe the state of the standardization work, the major issues being discussed, and open questions recently identified. Based on extensive first-hand experience, we discuss challenges in implementation of this new wave of standards. Lessons learned are highlighted from four popular open-source implementations of these standards: OpenWSN, Contiki, RIOT, and TinyOS. We outline major requirements, present insights from early interoperability testing and performance evaluations, and provide guidelines for chip manufacturers and implementers.
iwipcps.pdf (1.81 Mo) Télécharger le fichier
hal-01282597 , version 1 (20-12-2016)
Thomas Watteyne, Vlado Handziski, Xavier Vilajosana, Simon Duquennoy, Oliver Hahm, et al.. Industrial Wireless IP-based Cyber Physical Systems. Proceedings of the IEEE, 2016, 104 (5), pp.1025-1038. ⟨10.1109/JPROC.2015.2509186⟩. ⟨hal-01282597⟩
350 Consultations
711 Téléchargements
