Efficient and Enhanced Solutions for Content Sharing in DRM Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michal Davidson
  • Fonction : Auteur
  • PersonId : 978092
Ehud Gudes
  • Fonction : Auteur
  • PersonId : 978093
Tamir Tassa
  • Fonction : Auteur
  • PersonId : 978094
We present a solution to the problem of content sharing in digital rights management (DRM) systems. Users in DRM systems purchase content from content providers and then wish to distribute it between their own devices or to other users. The goal is to allow the sharing of such content, with the control of the content provider, while ensuring that it complies with the content’s usage rules. While most of the previous studies on content sharing in DRM systems assume the existence of authorized domains, ours does not make that assumption. The solutions that we present here are based on Certified Sharing Requests which are used when devices request from the content provider authorization to share content with other devices. Our solutions enhance the usability of DRM, from both the users’ and content provider’s perspective, by supporting on-the-fly sharing, sharing and re-sharing of controlled content, and a pay-per-share business model.
978-3-662-43936-4_25_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01284873 , version 1 (08-03-2016)
Paternité
Michal Davidson, Ehud Gudes, Tamir Tassa. Efficient and Enhanced Solutions for Content Sharing in DRM Systems. 28th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jul 2014, Vienna, Austria. pp.373-381, ⟨10.1007/978-3-662-43936-4_25⟩. ⟨hal-01284873⟩
60 Consultations
74 Téléchargements
