PDE-Driven Shape Optimization: Numerical Investigation of Different Descent Directions and Projections Using Penalization and Regularization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider shape optimization problems with elliptic partial differential state equations.Using regularization and penalization, unknown shapes are encoded via shape functions, turning the shape optimization into optimal control problems for the unknown functions. The method is designed to allow topological changes in a natural way. Based on convergence and differentiability results, numerical algorithms are formulated, using different descent directions and projections. The algorithms are assessed in a series of numerical experiments, applied to an elliptic PDE arising from an oil industry application with two unknown shapes, one giving the region where the PDE is solved, and the other determining the PDE’s coefficients.
978-3-662-45504-3_23_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01286429 , version 1 (10-03-2016)
Paternité
Peter Philip. PDE-Driven Shape Optimization: Numerical Investigation of Different Descent Directions and Projections Using Penalization and Regularization. 26th Conference on System Modeling and Optimization (CSMO), Sep 2013, Klagenfurt, Austria. pp.237-246, ⟨10.1007/978-3-662-45504-3_23⟩. ⟨hal-01286429⟩
50 Consultations
48 Téléchargements
