Performance evaluation of LoRa radio solution for PREDNET wildlife animal tracking project - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Performance evaluation of LoRa radio solution is provided based on coverage simulations and range tests. The full version of abstract is attached.
abstract_LPWAN16.pdf (829.4 Ko) Télécharger le fichier
hal-01288077 , version 1 (06-07-2016)
  • HAL Id : hal-01288077 , version 1
Viktor Toldov, Jan Pieter Meijers, Román Igual-Pérez, Riaan Wolhuter, Nathalie Mitton, et al.. Performance evaluation of LoRa radio solution for PREDNET wildlife animal tracking project. LPWAN 2016 - The 1st international conference on IoT and M2M wireless LPWA (Low Power Wide Area) technologies, May 2016, Paris Roissy, France. ⟨hal-01288077⟩
375 Consultations
996 Téléchargements
