Conference papers
Parallel Differential Evolution approach for Cloud workflow placements under simultaneous optimization of multiple objectives
Abstract : The recent rapid expansion of Cloud computing facilities triggers an attendant challenge to facility providers and users for methods for optimal placement of workflows on distributed resources, under the often-contradictory impulses of minimizing makespan, energy consumption, and other metrics. Evolutionary Optimization techniques that from theoretical principles are guaranteed to provide globally optimum solutions, are among the most powerful tools to achieve such optimal placements. Multi-Objective Evolutionary algorithms by design work upon contradictory objectives, gradually evolving across generations towards a converged Pareto front representing optimal decision variables – in this case the mapping of tasks to resources on clusters. However the computation time taken by such algorithms for convergence makes them prohibitive for real time placements because of the adverse impact on makespan. This work describes parallelization, on the same cluster, of a Multi-Objective Differential Evolution method (NSDE-2) for optimization of workflow placement, and the attendant speedups that bring the implicit accuracy of the method into the realm of practical utility. Experimental validation is performed on a real-life testbed using diverse Cloud traces. The solutions under different scheduling policies demonstrate significant reduction in energy consumption with some improvement in makespan.
Complete list of metadatas
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01289176
Contributor : Daniel Balouek-Thomert <>
Submitted on : Friday, June 10, 2016 - 3:05:22 PM
Last modification on : Monday, May 4, 2020 - 11:40:04 AM
File
CEC2016.pdf
Identifiers
  • HAL Id : hal-01289176, version 2
Citation
Daniel Balouek-Thomert, Arya K. Bhattacharya, Eddy Caron, Karunakar Gadireddy, Laurent Lefèvre. Parallel Differential Evolution approach for Cloud workflow placements under simultaneous optimization of multiple objectives. Congress on Evolutionary Computation (IEEE CEC 2016), Jul 2016, Vancouver, Canada. ⟨hal-01289176v2⟩
Share
Metrics
Record views
968
Files downloads
566
