Electron phase shift at the zero-bias anomaly of quantum point contacts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2016
Ulf Gennser
Pascal Simon
Serge Huant
  • Fonction : Auteur
  • PersonId : 957039
The Kondo effect is the many-body screening of a local spin by a cloud of electrons at very low temperature. It has been proposed as an explanation of the zero-bias anomaly in quantum point contacts where interactions drive a spontaneous charge localization. However, the Kondo origin of this anomaly remains under debate, and additional experimental evidence is necessary. Here we report on the first phase-sensitive measurement of the zero-bias anomaly in quantum point contacts using a scanning gate microscope to create an electronic interferometer. We observe an abrupt shift of the interference fringes by half a period in the bias range of the zero-bias anomaly, a behavior which cannot be reproduced by single-particle models. We instead relate it to the phase shift experienced by electrons scattering off a Kondo system. Our experiment therefore provides new evidence of this many-body effect in quantum point contacts.
1603.08680.pdf (4.58 Mo) Télécharger le fichier
hal-01294955 , version 1 (17-04-2024)
Boris Brun, Frederico Martins, Sebastien Faniel, Benoit Hackens, Antonella Cavanna, et al.. Electron phase shift at the zero-bias anomaly of quantum point contacts. Physical Review Letters, 2016, 116 (13), pp.136801. ⟨10.1103/PhysRevLett.116.136801⟩. ⟨hal-01294955⟩
156 Consultations
0 Téléchargements
