Journal articles
Space-time domain decomposition for advection-diffusion problems in mixed formulations
Abstract : This paper is concerned with the numerical solution of porous-media flow and transport problems , i. e. heterogeneous, advection-diffusion problems. Its aim is to investigate numerical schemes for these problems in which different time steps can be used in different parts of the domain. Global-in-time, non-overlapping domain-decomposition methods are coupled with operator splitting making possible the different treatment of the advection and diffusion terms. Two domain-decomposition methods are considered: one uses the time-dependent Steklov–Poincaré operator and the other uses optimized Schwarz waveform relaxation (OSWR) based on Robin transmission conditions. For each method, a mixed formulation of an interface problem on the space-time interface is derived, and different time grids are employed to adapt to different time scales in the subdomains. A generalized Neumann-Neumann preconditioner is proposed for the first method. To illustrate the two methods numerical results for two-dimensional problems with strong heterogeneities are presented. These include both academic problems and more realistic prototypes for simulations for the underground storage of nuclear waste.
Complete list of metadata
Cited literature [48 references]  Display  Hide  Download
https://hal.inria.fr/hal-01296348
Contributor : Caroline Japhet Connect in order to contact the contributor
Submitted on : Thursday, May 19, 2016 - 12:21:54 PM
Last modification on : Friday, January 21, 2022 - 3:19:14 AM
Advectionpaper_revised.pdf
Identifiers
Citation
Thi-Thao-Phuong Hoang, Caroline Japhet, Michel Kern, Jean E. Roberts. Space-time domain decomposition for advection-diffusion problems in mixed formulations. Mathematics and Computers in Simulation, Elsevier, 2016, MAMERN VI-2015: 6th International Conference on Approximation Methods and Numerical Modeling in Environment and Natural Resources, 137, pp.24. ⟨10.1016/j.matcom.2016.11.002⟩. ⟨hal-01296348v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
