The CMA Evolution Strategy: A Tutorial - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2005
Nikolaus Hansen
This tutorial introduces the CMA Evolution Strategy (ES), where CMA stands for Covariance Matrix Adaptation. The CMA-ES is a stochastic, or randomized, method for real-parameter (continuous domain) optimization of non-linear, non-convex functions. We try to motivate and derive the algorithm from intuitive concepts and from requirements of non-linear, non-convex search in continuous domain.
tutorial.pdf (518.12 Ko) Télécharger le fichier
hal-01297037 , version 1 (01-04-2016)
hal-01297037 , version 2 (09-03-2023)
Nikolaus Hansen. The CMA Evolution Strategy: A Tutorial. 2005. ⟨hal-01297037v1⟩
1998 Consultations
4190 Téléchargements
